PublishingTools Stops ...
1143
09-24-2012 07:23 AM
SercanERHAN1
In ArcGIS Server 10.1 on Centos 5.7 Final, PublishingTools service stops in 5seconds after restart it manually. It make stops Printingtools too. I couldn't resolve it.
In logs file it says a synchronization problem.. can you suggest a solution?
Failed to synchronize machine 'HOST-NAME' with the site. /opt/arcgis/server/framework/runtime/ejbs/System/PublishingTools.GPServer/Recycling (Is a directory)
SercanERHAN1
It seems solved after restarting ArcGSI Server..
