Publishing XY Event Layer
1708
01-18-2017 02:12 PM
GeoffreyWest
How can I publish an XY event layer and have changes which are made to the table made to the XY event layer published service as well ? I've made changes to the table, but they were not reflected in the published service. What is the solution so that I am able to see any changes made to the table, that they will be made to the XY event layer as well?
I am able to view the data via XY Event layer, which I initially thought was an in-memory layer, but it is, however, an instance of the view/or data set that I am using. The ideal scenario would be:
1.) Make event layer of XY from SDE table 2.) Publish service definition 3.) All changes will be reflected in published event layer.
I am using ArcGIS Server 10.4.1
