Publishing Spatial ETL Tools with output in ZIP format
742
01-25-2017 09:48 AM
TamiOnstad
I have a Spatial ETL tool which is set up to create the output inside a ZIP file.  This works great when run locally, and the path for the output looks like "C:\Output.Zip\Output.dwg.  I end up with a nice zip file on the local drive with the DWG inside.
However, when you publish, that original output path gets changed to a scratch workspace, and it removes all path info except the file name Output.dwg.  The path ends up looking like '%scratch%\Output.dwg'.  It removes all reference to the zip file, so it doesn't create a zip file in the output, only the DWG file.
How can I set this up to create a zip file when published?  Publishing a Spatial ETL does not involve ANY custom code of any kind - it relies on whatever parameters are set in the ETL tool.  So, I can't play with the output path or anything like that using Python or other programming language.
Has anyone tried to do this?
Tami
