Publish Print Service to Enterprise from ArcGIS Pro
2794
11-10-2023 05:44 AM
CameronLacelle
I am trying to use a custom print layout in Experience Builder for an application we are building for some of our end users to export their own maps of properties in our municipality. I was working through some other guides online for exporting an "ExportWebMap" tool with a shared layout file that I created. However all of these next steps involve publishing the print service using what I've done to a standalone server via the catalog pane in Pro. This doesn't match up to what I see on my catalog pane where the guides say "In the Catalog pane, right-click the server connection and choose Publish". I don't see where I can publish to my Enterprise portal in catalog.
Hoping someone can help so I can publish a custom print service to Enterprise and use this for the current application, and create other custom print services for Enterprise down the road as my team and I migrate fully to an Enterprise-based GIS in our organization.
A_Wyn_Jones
Hi @CameronLacelle,
I believe you need to go to the analysis tab and select the history menu. From here you can right-click the ExportWebMap job and share to portal. Please see the following documentation:
https://enterprise.arcgis.com/en/server/10.9.1/publish-services/windows/tutorial-publish-additional-...
As a note, please ensure you're using the right version of ArcGIS Pro for your version of Enterprise. Please see:
https://pro.arcgis.com/en/pro-app/latest/help/analysis/geoprocessing/share-analysis/geoprocessing-se...
"We've boosted the Anti-Mass Spectrometer to 105 percent. Bit of a gamble, but we need the extra resolution."
CameronLacelle
I've done this, I see it as a utility to add but it says "This utility service is not supported". I will try to re-export again, I've followed that same documentation that you sent and my ArcGIS Pro is up to date along with my Enterprise.
TanuHoque
@CameronLacelle
is your print service's Execution Mode Sync or Async? If it is set to Async, change it to Sync and then try from Experience Builder.
CameronLacelle
I've set it to sync when I created the ExportWebMap, I followed the documentation to re-export the service to Enterprise sent by A_Wyn_Jones above, but now I am running into issues with my version of Pro and Enterprise as I just updated my ArcGIS Pro but I suppose now it's out of sync with the version of Enterprise our organization is running so I'm at a standstill until we get our Enterprise also updated.
I am hopeful that it will work this time though, thank you for your help.
