Publish .dwg layer to ArcGIS Server
3259
12-01-2014 07:06 AM
JonathanMeyer
I'm looking for a way to publish a .dwg layer to ArcGIS Server 10.2.2.  DWG's used to be a supported source data layer type.  When publishing a map with a .dwg layer I get an error stating that the layer type is not supported.  So trying a different route and using the interoperability extension for desktop and server.  I try publishing using data from an interoperability connection.  The map publishes without error but the data doesn't show up.  Anyone have any suggestions or know if this is even possible?
