Problem with cache and AGOL Tiles
1448
01-26-2017 07:16 AM
PanGIS
need to clarify things regarding map caching as I need to solve a performance problem:
Server 10.2
Map published as a service, cashed till tile 19 (1:1128) AGOL cache.
The data and map (mxd) are all in WGS84 (I need this as it better this coordinate for data).
The service is published in Web Mercator as I  need this for a AGOL service to work.
The service is used by an app.
As soon as I zoom in too close (different tiles for imagery and topographic) the message "Map not available yet" appears.
Now, what is it better?:
  • Recreate the tile in a custom mode: I have realized that if I delete the cache and I tile again from the service properties I can change the tile scheme and tile the map as I want. The map is still in Web Mercator and the tile are customized (tested on another service).
  • Remove the tile and use the dynamic data.
  • Limit the zoom with an app customization (QT)  (no idea if I can as I don't make code, I would ask if is it possible).
I would go for the first one but I am worried that I can mess something with that. Any idea?
Limit the zoom on a map can work?
Thanks.
Tags (4)
AdamZiegler1
Hi - Ideally the App would recognize the cached map service as a basemap and stop you from zooming in too far. If this isn't an option, you could add zoom levels without completely overhauling your cache. In the Server Tools --> Caching Toolbox you can use the 'Manage Map Server Cache Scales' to add or delete cache levels.
-Adam Z
