PostgreSQL License - STGeometry Extension
1441
01-15-2026 03:23 AM
denniszammarchi
Good morning,
a user needs to create an Enterprise DB with PostgreSQL, but does not have an ArcGIS Enterprise licence. Is there a way to create the DB without losing all the Esri features for Postgre? He is not interested in creating it and using extensions such as PostGIS.
Is the ST_Geometry spatial extension only available with an ArcGIS Enterprise licence?
Best regards!
George_Thompson
Esri Notable Contributor
Roger, as mentioned to build an Enterprise Geodatabase (on any of the supported RDBMS's) it requires an ArcGIS Server license.
--- George T.
George_Thompson
You can enable PostGIS on the database without the required license. You will not be able to have the full functionality of an Enterprise Geodatabase (https://enterprise.arcgis.com/en/server/latest/manage-data/linux/enterprise-geodatabases-and-arcgis-...), or Esri features as you mentioned without the needed license file.
You can also install the ST_Geometry spatial type: https://pro.arcgis.com/en/pro-app/latest/help/data/databases/add-the-st-geometry-type-to-a-postgresq... (details about it in PostgreSQL - https://pro.arcgis.com/en/pro-app/latest/help/data/databases/overview-database-spatial-types.htm#ESR...)
Hope this helps!
--- George T.
denniszammarchi
Thanks for the feedback, George!
So, do we need an Enterprise licence for ST_Geometry?
Have a nice day!
--- Dennis
George_Thompson
I am not 100% sure, but do not think so. Based on the doc above, it does not appear to be needed.
Just remember that it will NOT be a geodatabase if you add the ST_Geometry type. It will just add another spatial storage method.
I am not sure why you would want to have both in the database without the GDB functions.
What are you going to do with ST that you cannot do with PostGIS?
--- George T.
denniszammarchi
Because we want to know if it is possible to build a geodatabase using PostgreSQL in ArcGIS Pro Standard or Advanced (without ArcGIS Enterprise), and we are evaluating PostGIS and ST_Geometry extensions.
thank you for all the informations!
George_Thompson
--- George T.
