postgres: could not find the database system
2212
09-12-2023 11:26 AM
RobStauder
Our Datastore suddenly stopped working this morning and wrote this error into the system error log:
postgres: could not find the database system Expected to find it in the directory "C:/arcgisdatastore/pgdata", but could not open file "C:/arcgisdatastore/pgdata/global/pg_control": No such file or directory
I was able to confirm that there is no pg_control file or folder in global.
describedatastore returns this -
Error encountered: No valid connection to ArcGIS Data Store configuration store established.
Caused by: Connection to localhost:9876 refused. Check that the hostname and port are correct and that the postmaster is accepting TCP/IP connections.
I checked the firewall and 9876 is not open. This seems odd given that the site has been up for quite some time now.
Any ideas? Just open the port?
Dan_Brumm
Rob
 I have had this happen to me many times. Everything is working fine and then magically localhost:9876 refused.  This happens to systems I rarely touch more often than my Production system.
For me, 95% of the time I reboot my host and it will come back online. The other 5% require a uninstall / reinstall.   I also have this trick where I make a change to the security settings of my ArcGIS Server (change https only to http/https) and save those changes and sometimes that will bring it back.
I will say at 10.9.1 I have had better luck with my datastores.
Dan
Daniel Brumm
GIS Nerd
RobStauder
A friend of mine reminded me to add the version - 11.1.
We reverted to a previous snapshot. The site is now back up.
Thanks for your input @Daniel
