Portaladmin not accessible after installation
6467
13
12-27-2021 08:36 AM
conde
I did a fresh ArcGIS Portal 10.9.1 installation (on my laptop and on a server).
Site creation is successfully completed and I can login to arcgis/home with portal admin user.
But I am not able to log in portaladmin.
When I go to "https://portal.host.machine:7443/arcgis/portaladmin/" I see below screen.
I have tried on different browser (Edge, Firefox, Chrome, IE), same result.
I have no error in the portal logs.
Do you have any idea to solve the problem?
ReeseFacendini
Esri Alum
If you are able to get to the page shown in your original screenshot, then you are able to get to /portaladmin.  10.9 /10.9.1 changed the landing page, and there is now a login button (upper left, under the bold text), instead of the form for entering a username / password.
jcarlson
What about just going to portal.host.webadaptor/portaladmin?
- Josh Carlson
Kendall County GIS
conde
The same! not working either.
I have installed the 10.8.1 version of portal and it's perfectly working.
The issue is surely related to the 10.9.1 version.
BillFox
MVP Notable Contributor
How do you have the new web adaptor configured? Authentication, SSL, etc.? same for portal?
conde
Right now I don't have a webadaptor configured. I'm trying to access via the 7443 port. I just installed portal, so there no additionnal authentification (using built-in), no external certificate (using portal autosigned).
jcarlson
When you say portal admin user, are you referring to a named user, or the local machine's user specified during installation?
If not the latter, can you attempt logging in as that user?
- Josh Carlson
Kendall County GIS
conde
i'm referring to portaladmin account specified when creating the portal site.
I can log in to /arcgis/home with this account
JayantaPoddar
I assume you have tried using URL similar to https://webadaptorhost.domain.com/webadaptorname/portaladmin
Could you test the following?
- Could you ensure that you are not currently logged in to ArcGIS Enterprise using non-admin user?
- Try connecting to the above URL in incognito mode.
- Clear Browser cache and restart browser.
- Try a different browser
Think Location
conde
No i'm using https://fqdn:7443/arcgis/portaladmin and i have done all the tests you mentionned. Same result
ReeseFacendini
Esri Alum
