Portal Allow Origins Web App Builder Redirect
2424
07-07-2019 02:39 PM
ClintonBallandis1
Hi all,
I've just upgraded my Web App Builder to version 2.12 and have associated it with my Portal that is running 10.6.1.
I can successfully open Web App Builder and create a project however only when I don't enter values in the Portals Security Allow Origins field.
This seems to be at odds with the following technical document https://support.esri.com/en/technical-article/000018879 that suggest that Web App Builder won't work unless your machinename.domain is added to the Allow Origins white list ?
If I add the domain name of the machine to the Allow Origins I get a continuous login redirect when I try to approve access to the portal.
I was going to add the following to the Allow Origins to restrict CORS requests -  my domain e.g. https://xyz.com
any machines that have web app builder installed https://machine1name.domain https://machine2name.domain
Rebecca Strauch, GISP you did you ever add Allow Origins to AGOL as per this thread https://community.esri.com/thread/175351
Clinton
RebeccaStrauch__GISP
Hi Clinton, I've been "offline" GIS wise for about a year.  Just starting to look at things again, so I'm not at a point that I can answer your question.  It's amazing how much changes in a year.
ClintonBallandis1
Hi Rebecca,
Thanks for the reply. Welcome back to GIS !
