Pooling/instance concept,
8516
10
05-28-2013 10:58 AM
JamalNUMAN
Legendary Contributor
A web application is built to reads its url from:
http://jamal-pc:6080/arcgis/rest/services/T5/MapServer
the minimum number of instances per machine is set to be 1
the maximum number of instances per machine is set to be 2
[ATTACH=CONFIG]24745[/ATTACH]
does this mean that the maximum number of users who can access the web application (that served from the above mentioned url) is 2? Then if three clients, for example, access the web application then what might happen?
Thank you
Best
Jamal
Jamal Numan
JamalNUMAN
Thanks David for the valuable input.
But what is the instance?
Do you agree with the description above for the CPU, requests, and instance?
Requests: Cars
CPU: Lanes
Instance: Toll
What is the thread and ArcSoc.exe in this case?
Jamal Numan
