parameters for projected system
2981
11-05-2014 10:48 PM
jayasudha
Hi experts
I have the following parameters from ESRI document to set in dbtune
##SDO_GEOMETRY_8307
GEOMETRY_STORAGE "SDO_GEOMETRY"
SDO_INDEX_SHAPE "sdo_indx_dims=2"
SDO_SRID 8307
SDO_DIMNAME_1 "Lon"
SDO_LB_1 -180.000000
SDO_UB_1 180.000000
SDO_TOLERANCE_1 0.05
SDO_DIMNAME_2 "Lat"
SDO_LB_2 -90.000000
SDO_UB_2 90.000000
SDO_TOLERANCE_2 0.05
UI_TEXT "Oracle Spatial: WGS84"
END
Need your help to know the similar parameters to set for SDO_GEOMETRY_32616 (UTM Zone 16).
XanderBakker
Esri Esteemed Contributor
I don't have the parameters for you, but maybe this site helps you in defining the parameters:
WGS 84 / UTM zone 16N - EPSG:32616
Kind regards, Xander
jayasudha
Thanks, it is useful link
