Overwrite Existing Map Service hangs
3494
04-26-2013 08:27 AM
TimHayes
I am using SQL Server 2008 R2, SDE, with a Replicated File Geodatabase. Not using 10.1 SP1.
Each time I overwrite an existing Map Service (after I updated the mxd) in ArcGIS Desktop ArcMap it hangs at the "Publishing in Progress - Data Transfer to Server is Complete - Processing data on server - Please Wait" Window. The Window says "Publishing in Progress..." and just keeps processing and processing. Nothing happens.
I tried rebooting my server. No change.
Any ideas?
RobertJones2
Might be worth reviewing the ArcGIS Server logs with detailed logging?
by Anonymous User
Not applicable
Any ideas?
Did you ever find a fix for this?
Thanks!
Rgibson
TimHayes
ESRI tells me this is a bug resulting from the major Windows update in March/April 2013. They said it will be fixed when 10.2 is released.
