Order to enable attachments, archiving, editor tracking
812
09-14-2023 10:47 AM
kapalczynski
Is there an order you should follow to enable attachments, archiving, editor tracking on a Feature Classes
Kara_Shindle
Yes, at least if you are planning to Enable Sync, such as if you are enabling the consumption of the existing layer in Survey123 Connect.  If you are doing it for Survey123 Connect, then the steps are performed in a certain order to enable the supportsApplyEditsWithGlobalIDs setting. See this blog post and this blog post for more on that.
kapalczynski
I just dont see in there the order...
  1. Enable Attachments
  2. Enable Editor Tracking
  3. Enable Archiving
OR
  1. Enable Archiving
  2. Enable Attachments
  3. Enable Editor Tracking
