ORA-20005: Invalid (NULL) Lob locator (points). ORA-06512: "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 325...
6846
6
02-16-2017 09:09 AM
MarceloEdy_Peinado
I have a problem while execute a ST_Geometry functions! 😕
The error message is:
ORA-06512: in "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 325
ORA-06512: in "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 1331
Anyone could help me?
Environment:
ArcGIS 10.4
Oracle:  11.2.0.1.0
OS:  Oracle Linux Server release 6.6
         Red Hat Enterprise Linux Server release 6.6 (Santiago)
Thanks and regards,
Marcelo Edy Peinado
Environmental Engineer
Optimus GIS & IT Solutions
Tags (1)
by Anonymous User
Not applicable
Dear Marcelo
Can you check if st_geometry has been configured correctly? Can you execute this query:
select sde.ST_AsText(SDE.ST_Geometry('POINT (10 10)', 0)) from dual;
without errors?
Or... did you configured anyway the ST_GEOM_LOG_STORAGE parameter? Take a look at:
ST_Geometry in Oracle—Help | ArcGIS Desktop
Hope this helps
Jesús de Diego
by Anonymous User
Not applicable
Dear Marcelo
without errors?
Hope this helps
Jesús de Diego
MarceloEdy_Peinado
Hi Jesús,
Thanks for your assistance!
After create another tablespace and adjust the DBTUNE to store data on LOB_SEGMENT the problem was solved!
Best regards,
Marcelo E. Peinado
ManviLather1
I would appreciate if you could have a look at the following BUG:
BUG-000090937
Here is link for reference :
http://support.esri.com/bugs/nimbus/QlVHLTAwMDA5MDkzNw==
Try using the workaround and let me know how it goes:
Use the following filter in SQL queries: WHERE SDE.ST_ISEMPTY(SHAPE) = 0; OR WHERE A.SHAPE.POINTS IS NOT NULL;
Asrujit_SenGupta
KevinGooss
I am now seeing this error as well on sde 10.4.1 i believe it is recent that this has cropped up.Any resolutions out there?
Asrujit_SenGupta
BUG-000090937: Invalid (NULL) Lob locator (points) errors are retur..
Yes, as per the details in the Bug, it seems to be an issues since 10.3.1.
Alternate Solution
OR
