Only activate one layer in a webmap, It is possible?. When one layer is activated, the others are deactivated.
2183
10-13-2023 05:38 AM
jdelabrgc
Hi!
It is possible to limit a webmap so that it can only have one active layer?
Even if there are 2 or 10 layers, it allows me to activate any one but automatically deactivate the one that is active.
 Thank
MarkBockenhauer
You might be interested in exclusive visibility in a group layer ?
jdelabrgc
Thank you Mark.
Do you use Enterprise or Online?
What version does the map viewer use? I use Enterprise in version 11.1 and that function does not appear.
Regarding the visibility of layers it only allows me to manipulate the visible range
MarkBockenhauer
Exclusive Visibility will be available in Enterprise 11.2
berniejconnors
That is an interesting idea.  So the layers widget would have radio buttons instead of check boxes.  Sorry, I don't have an answer for you.  It sounds like a custom widget is what you would need.
Bernie.
PeterKT
Exclusive visibility is only for layers in groups?  I'd prefer to have my very simple map with only four layers to have exclusive visibility.
Peter T, Brisbane
