Old web app using Javascript API 3.8 - compatible with ArcServer 10.9.1 services published through Pro?
1500
09-28-2023 11:54 AM
AllenScully2
Hi -
We have an old web app that uses Javascript API 3.8.
It has been showing a few bug like behaviors since the ArcServer version for the services it uses moved from 10.7.1 to 10.9.1, and they were re-created and published from ArcPro 3.1.
     - Specifically, selection behavior on the map - one feature can be selected but not multiple features.
Seems like there may be a compatibility issue - but I am not a developer and haven't found documentation specifically addressing this -
Scott_Tansley
MVP Regular Contributor
Hi, this probably isn't strictly the answer to your question, but I'd recommend you looking at:
https://support.esri.com/en-us/products/arcgis-api-for-javascript/life-cycle
The version you're using hasn't been supported since Aug 1, 2022.  It was probably released somewhere around 2013-2015 as a guess.  The whole 3.x set of libraries is due for deprecation on 30/06/2024 and so it would probably make sense to start looking at using another approach to this application as a matter of urgency.
There is a good degree of forward/backwards compatibility with the JavaScript/Rest APIs, but this is pushing the boundaries a bit.
Scott Tansley
https://www.linkedin.com/in/scotttansley/
