Object Store Cluster Validation 11.5
530
03-24-2026 04:30 AM
SimonSchütte_ct
MVP Regular Contributor
I have a Object Store Cluster deployed in 11.5.
For reasons I had to unregister the Object Store. When I registered the Object stores again, they failed to validate in the server validation endpoint (admin/data/items/cloudStores/...). No issues in describedatastore.
How to fix the cluster if it fails to establish?
The health checks are inconsistent across machines and there is no documentation explaining the parameters:
DeploymentMode: cluster
finalized: true
ValidationObjectStore1ObjectStore2ObjectStore3
machine.overalhealthTransitionalTransitionalTransitional
rolecluster_membercluster_membercluster_member
healthcheck.enablefalsefalsefalse
statusStartingStartingStarting
isSCMhealthytruetruetrue
isOMHealthytruefalsefalse
isDataNodeHealthyfalsefalsefalse
isS3GHealthyfalsetruetrue
(isSCMPrimordialNode)true (managerNumber 1)(managerNumber 2)(managerNumber 3)
datastore.overalhealth: Unhealthy
1) What is SCM, OM, DataNode, S3G? Maybe StorageClusterManager, Object Manager, DataNode (for replication?), S3-Gateway internal?
2) How to fix the cluster? What is wrong?
My personal feeling is that the cluster is not syncing correctly. Only option I see is to delete the datastore config|data folder and start from scratch, but this involves many steps to prevent data loss, I´d like to avoid this. I would prefer a way to re-establish the cluster as-is.
Similar but other issue: Clean Install Object Store Cluster 11.5 Unhealthy - Esri Community
SimonSchütte_ct
We fixed the cluster be resetting all object stores (this step will cause loss of data if stored in object store). We than reconfigured them again.
