mxdperfstat issues
3025
02-09-2012 03:46 AM
by Anonymous User
Not applicable
Attempting to run mxdperfstat on a simple mxd with minimal results being returned.
Basically while the app will run, launch mxd & close, its doing nil tests in between & log file generated contains min info.  Setting other option parameters such as scales, screen resolution has nil impact.
Running off 64-bit machine with ArcGIS 10 Desktop SP2; nil errors in log (actually very little info in log).
Any suggestions by anyone?
Brad
by Anonymous User
Not applicable
Answering myself.... it would appear that it only will work within the scales of your maximum extent of your layers... in my case its below 1:250 as dealing with a building footprint.
Brad
