Multiple Vulnerabilities in embedded Apache Tomcat - ArcGIS Server and Portal. CVE-2025-55668, CVE-2025-48989
1847
08-20-2025 01:43 AM
vipulsoni
We have ArcGIS Server 11.5 and ArcGIS Portal 11.3 in production environment with the below highlighted vulnerabilities by our organization Cyber Security Team. please need advice for the same, since i have not been able to find any patches or documents which addresses the exact same vulnerabilities for the specific ArcGIS Enterprise Versions.
This advisory addresses Apache Tomcat security updates addressing two major vulnerabilities, impacting several supported versions of its open-source application server. These vulnerabilities could be exploited to carry out session fixation attacks or trigger denial-of-service (DoS) using the MadeYouReset method in HTTP/2.
CVE-2025-55668 - Session Fixation via Rewrite Valve
6.5 Medium
Apache Tomcat's rewrite valve mechanism contains a session fixation flaw, which could let attackers assign a session ID to a user before they log in, potentially enabling session hijacking.
CVE-2025-48989 - Denial-of-Service via MadeYouReset HTTP/2 Technique
7.5 High
Apache Tomcat is susceptible to the MadeYouReset attack, which exploits the HTTP/2 protocol by mishandling stream resets, leading to resource exhaustion.
A_Wyn_Jones
Could you please report these via the ArcGIS trust center:
https://trust.arcgis.com/en/security-concern/
This will get you the response you need from the appropriate people.
"We've boosted the Anti-Mass Spectrometer to 105 percent. Bit of a gamble, but we need the extra resolution."
