Migrating Single to Multi Machine Enterprise - File Share Confusion
2309
8
04-28-2025 09:25 PM
CW-GIS
We are migrating from a single machine deployment to a multi machine deployment. We are in Azure and have an Azure File Share connected to each machine as a drive (Z).
When installing Portal 11.4, it would not let me install the content directory to the file share drive (Z). After installation, I went to portal admin and tried to change it from System > Directories, but I get this error:
which doesn't exist, but that path also doesn't exist in the current directory.
Question: Is the Portal content directory supposed to go on the File Share? or is it just the Server configuration directory?
SimonSchütte_ct
MVP Regular Contributor
Did you copy the content directory to the new location before trying to change the path in Portal Admin?
The Admin endpoint will not copy the directory for you.
"In a highly available configuration, the portal's content directory is shared between both machines.
  1. On the file server, create a directory for the portal's content directory, and share it so that it can be accessed by both portal machines. For example, \\share\portal\content."
see: Configure a highly available portal—Portal for ArcGIS | Documentation for ArcGIS Enterprise
Note: I assume you extend your current deployment to a HA deployment and need to move the content directory to a shared location.
In case you intend to migrate a normal deployment to a HA deployment (moving from another environment to a new HA environment) other steps need to be taken.
CW-GIS
Yes, I copied the content directory to the new location beforehand.
We are migrating a normal deployment to a HA deployment. What are the other steps that need to be taken?
CW-GIS
Edit to my original post:
content/items/accountresources/0123456789ABCDEF/accountSettings
Does exist in both places (it's just deep in the middle alphabetically)
SimonSchütte_ct
A) Do you expand your existing environment 1 to a HA environment 1+2SimonSchtte_ct_0-1745939088702.png
B) or do you migrate to a new HA environment and tried something like this?
Depending on your setup, other workflows need to be used, for example Migrate to a new machine in ArcGIS Enterprise.
I highly recommend you  High availability | ArcGIS Architecture Center
There are many things to consider, depending on what deployment/steps you took/plan to take.
Single machine/multi machine, active/passive, active/active,... probably too much to discuss in length here.
Other useful links: How to make your ArcGIS Enterprise environment robust | Esri Australia Technical BlogPlanning Load Balancer Configuration for Highly Available ArcGIS Enterprise
BillFox
MVP Notable Contributor
if you are going HA, hopefully you have the option to build the new environment from scratch
like @SimonSchütte_ct mentions, a migration to that world is a very deep dive that can break a lot of things
CW-GIS
@BillFox Yes we are building it from scratch in a new resource group. Then after we will move content.
SimonSchütte_ct
Ok, this simplifies troubleshooting.
Did you specify the file share as location for the first Portal installation and it failed?
What did you paste into the Edit Directory field?
I have seen the error you get, when \, / or // instead of \\ was used or the \\content was missing.
When entering a shared network location, the connection string syntax is formatted in this way: "connectionString":"\\\\<machinename>\\arcgisportal\\content"
When configuring the Portal and you need to specify the content directory, directory formatting could also block you from using this directory (happened to me before until I noticed / instead of \). [btw. When installing using ArcGIS PowershellDSC it is easy to specify the different storage locations (->ContentDirectoryLocation).]
Documentation reference:
Change the portal content directory—Portal for ArcGIS | Documentation for ArcGIS Enterprise
BillFox
yep, these slash things are trial and error
....etc
