Map Services - crosslinked data
2481
03-28-2013 06:27 AM
LuciHawkins
Hey,
I am experiencing problems with a couple of my map services.  It seems as though they are cross-linking data.  See ArcGIS 10.1 Server error log:
[ATTACH=CONFIG]23030[/ATTACH]
I am getting an error about layer wFitting in map service FWBWater not drawing.  The error right before that one references and "Invalid colunm name 'Subtye' for swFitting in map service FWBWater.  Well,  swFitting is not even IN the map service FWBWater - it is in map service FWBStormwater.
When I use the "identify" tool in my flexviewer app and click on a swFitting,  I get two popups - one for the swFitting data and one for wFitting data - any common field names are populated with the swFitting data in the wFitting popup.
FWBGDBpublic is a SQL database
FWBWater - is a dataset in FWBGDBpublic
wFitting  - is a feature class in FWBWater dataset
FWBStormwater - is a dataset in FWBGDBpublic
swFitting - is a feature class in FWBStormwater dataset
NONE of the FWBWater data is in the FWBStormwater map service and NONE of the FWBStormwater data is in the FWBWater map service.
Anyone else ever experience this?
I have deleted the services.  Recreated the services and still get the same errors.
Luci
LuciHawkins
Here are screen shots from the two map service rest points:
[ATTACH=CONFIG]23031[/ATTACH]
[ATTACH=CONFIG]23032[/ATTACH]
Here are screen shots from the two datasets in my SQL GDB:
[ATTACH=CONFIG]23033[/ATTACH]
[ATTACH=CONFIG]23034[/ATTACH]
Luci
TomMagdaleno
Have you tried switching from low isolation to high isolation?
LuciHawkins
Well, after several phone calls and several attempts using as many different ways as you can to create a new geodatabase, it seems as though my server just did not like my database name.  I used another database name and have not had any problems.  FWBGDBpublic - cannot use this name on our sever - FWBPublicGDB - worked just fine - so after repairing data sources on all maps and republishing them everything is working as it should now.
Luci
