ArcGIS Server 10.1 - Map export quality (dpi)
1253
04-16-2013 06:08 PM
HusenKang
Hi
Can someone help me to confirm the bug I am experiencing with ArcGIS Server 10.1?
Here are the steps to produce:
- Publish a dynamic map service (if you don???t have one set up)
- Add this map service to ArcMap
- Zoom in to an area that has point/line features
- Go to File>>Export Map...
- Choose resolution 96 dpi and save as type JPEG (or any type you want)
- Click save
- Now produce another export with resolution 600 dpi
- Compare the exported file
The export quality is different to 10.0. If the dpi is set to higher value than 96 dpi. The symbology of line and point features become big.
Thank you.
Husen
RadekPohl
I'm experiencing the same problem (desktop 10.1, server 10.1), 600dpi image is far from what I would expect, line symbols are clearly unproportionally exaggerated, If I shrink that 600dpi image  to 96dpi, I get completely different look opposite to original 96dpi version ... also polygon fills (line fill used) are malformed (fill looks like zoomed, what is similar to these "too fat" lines mentioned above)
Radek Pohl
