Live Update Feature Service on ArcServer 10.2 (linux)
2791
09-11-2013 06:35 AM
PaulKamis
I have a series of feature services/map services I have published onto an instance of ArcServer 10.2 on linux backed by a PostGreSQL DBMS.  All of my services represent data that updates at regular intervals (some as often as every five minutes).
Is it possible to update the data for these services without re-publishing the service each time I receive new data?  It seems like with the deprecation of the SDE command line utilities, my options are somewhat limited with backend data updates to the Geodatabase.  What are the options with 10.2?
KevinBell
I have FC's that update every minute with out issue...  The main idea is you can't change your FC's schema, but you can delete all the  rows and then use an insert cursor to reload and it doesn't require stopping the service.
