License Roles for Widgets
980
09-17-2023 10:36 AM
SanjayRana
Does anyone know of a list that states  WAB widgets and  required respective roles (i.e., viewer, creator, editor etc ) in the portal?
Thanks a lot in advance.
anbinh
I am not sure this is a legit question. WAB widgets are not directly associated with any user roles. Roles and user types define whether a user can publish/edit data etc., so if a user is not given the editor role, then this user certainly cannot edit the data, the then Editor widget would be quite useless for this user.
I would just read the User types, roles, and privileges—Portal for ArcGIS | Documentation for ArcGIS Enterprise to dig what user tyles have what privileges, but I don't see the point of joining WAB widgets with the user roles.
Cheers,
AB
SanjayRana
Thanks AB. You've actually sort of hinted at the answer i.e., relationship between editor widget and editor role.
This is an easy one though. I just thought that role-widget relationship would be a useful addition in the description page of each widget.
