Join table and ArcGIS Server
1683
11-21-2016 06:44 AM
deleted-user-0W0-oLHxDjCX
Hello everyone
We are having trouble to represent joint feature classes on ArcGIS Server 10.4.
Sometimes the layer name is truncated some others the layer is not represented on the map.
The join is made using a table view (toolbox:make table view). #important
Can you tell me if there is any trouble on ArcGIS Server 10.4 release?
 Is there any best preactices for using joined feature classes and thematic maps?
Here is the result of joined feature class with a table in the same database:
The upper layer is the database connection and the lower (that do not appears is an ArcGIS Server connection)
Sincerely
It looks this is an addressed issue reported at NIM099332. Could you tell me something about that rscheitlin‌?
RobertScheitlin__GISP
Ezequias,
   Sorry, I don't have any knowledge about that.
