Is the server capacity to accommodate web services is based on physical or logical number of cores?
1681
04-04-2017 01:06 AM
ArwaShaqour
Hi All,
We are trying to find the limitation for the number of ArcSoc.exe (generated when publishing services using ArcGIS Server) that can be accommodated in a server.
I would appreciate if anyone can hep me .
best,
Arwa
RandallWilliams
Logical cores, but memory is your primary limiting factor. Processor generally comes into play more with GP than with Mapping Services.
Honestly, there's not a well defined answer here that's going to fit for every use case - it depends on:
a. The resources available on the GIS Server machine - both memory and processor
b. The type of services you're running (Map/Feature or GP or Image or...?)
c. Virtual memory and desktop heap allocation
etc
The following documentation goes into depth:
http://www.wiki.gis.com/wiki/index.php/Capacity_Planning_Tool
http://www.wiki.gis.com/wiki/index.php/Server_Software_Performance
ArwaShaqour
thanks Randall for your reply , I will read these documentations.
