Is Arc Server 10.1 SP1  Software Version 10.1.1?
2662
10-23-2013 08:26 AM
GyeyoungChoi
Hi all,
I just installed 10.1 SP1 for server because of ERROR 001272: Analyzer errors were encountered (codes = 7)
however still getting same problem.
Wanted to make sure that the server upgrade went fine.
Software version:
10.1.1 (build 3143)
is this 10.1 SP1?
Jack
NidhinKarthikeyan
Honored Contributor
Jack,
The build number of 10.1 SP1 is 3143. I don't think, applying 10.1 SP1 will fix the error.
You can take a look at this forum post which is specific to the problem you are facing.
Regards,
GyeyoungChoi
Jack,
Regards,
Thank you for comment Nidhin,
Jack
TanuHoque
Jack,
This was a Desktop bug (not a server side issue) during publishing which got fixed in 10.2.
http://support.esri.com/en/bugs/nimbus/role/beta10_1/TklNMDgyNzY0
Please upgrade your ArcMap to 10.2 that should resolve the issue for you.
