import EPK file error "this file type is not supported" when I add this package as an item to my Portal 10.9.1.
1858
10-05-2022 09:07 AM
DiegoLlamasOlivares
Hello,
I am doing some test using export and import groups data. I was able to export a group content and download it  as test_20221005_112827.epk and when I am trying to do the exercise to import the epk file to other portal, fist I use add new item option in order to get item id for import and I got this error.
I also tried to do this from Server admin api and I got the same error.
and from this esri's web page says i can add this item
https://enterprise.arcgis.com/en/portal/10.9.1/use/supported-items.htm
I tried to add this item in 3 separates 10.9.1 portals and in all of them I got the same error.
What can It be?
Regards,
Diego
StevenBowleyParsons
epk file needs to be zipped before upload.  You can also import it through ArcGIS Server backend, following this guide: https://www.esri.com/arcgis-blog/products/arcgis-enterprise/administration/moving-content-across-tie...
