Hello
I user ArcGIS Enterprise Version 10.8.1 and i have issue to register Postgres database but I can register Sql Database and Get these Error
(The connection property set was missing a required property or the property value was unrecognized. The connection property set was missing a required property or the property value was unrecognized)
What is the version of Postgres that you are using?
Is the database a geodatabase? If so, what is the version of the geodatabase?
Do you have the pg_hba.conf configured to allow the server machine to connect?
Are you able to connect via PGAdmin from the server machine to the PostgreSQL database?
Postgres Version is PostgreSQL_12.2
and the pg_hba.conf is configured as attached
and i can connect via PG admin and connect to database
Ok, is there Pro on the Server machine that can connect to the PG database?
Is it an enterprise geodatabase or just a PG database?
Just to be sure, this PostgreSQL DB is NOT the one being used by datastore?
thanks Pro
the database is created by arcgis pro
Ok, thanks for that. You may need to work with technical support on this for a deeper dive into it.
