I cant to Register Postgres database
1399
06-21-2023 02:22 AM
AhmedTarek123
Hello
I user ArcGIS Enterprise Version 10.8.1 and i have issue to register  Postgres database but I can register Sql Database  and Get these Error
(The connection property set was missing a required property or the property value was unrecognized. The connection property set was missing a required property or the property value was unrecognized)
George_Thompson
Esri Notable Contributor
What is the version of Postgres that you are using?
Is the database a geodatabase? If so, what is the version of the geodatabase?
Do you have the pg_hba.conf configured to allow the server machine to connect?
Are you able to connect via PGAdmin from the server machine to the PostgreSQL database?
--- George T.
AhmedTarek123
Postgres Version is  PostgreSQL_12.2
and the pg_hba.conf is configured as attached
and i can connect via PG admin and connect to database
George_Thompson
Ok, is there Pro on the Server machine that can connect to the PG database?
Is it an enterprise geodatabase or just a PG database?
Just to be sure, this PostgreSQL DB is NOT the one being used by datastore?
--- George T.
AhmedTarek123
thanks Pro
the database is created by arcgis pro
George_Thompson
Ok, thanks for that. You may need to work with technical support on this for a deeper dive into it.
--- George T.
