How to update a hosted Map Image Layer via script in ArcGIS Enterprise?
2643
06-04-2024 02:31 AM
MaikeObenhaus
I have published a layer from ArcGIS Pro to ArcGIS Enterprise as a hosted Map Image Layer. I would like to regularly update this layer using python.
For hosted Feature Layer I have found scripting examples, which work. However, these overwrite the Service Definition. Since Map Image Layers don't have Service Definitions, how is it possible to update these via script?
MaikeObenhaus
JakeSkinner
Esri Esteemed Contributor
Hi @MaikeObenhaus,
Are you able to register the geodatabase/folder where the data resides with ArcGIS Server?  If you can, you can publish as a referenced Map Image, and the service will automatically update.
MaikeObenhaus
Hi @JakeSkinner, thanks for the reply! I tried referencing the data from our Oracle database, as well as publishing and hosting as a Feature, but in both cases the performance was too slow. So currently my only option is hosting as a Map Image Layer and regularly updating the data.
MaikeObenhaus
I ended up using arcpy. The following site helped me: https://pro.arcgis.com/en/pro-app/latest/arcpy/sharing/mapimagesharingdraft-class.htm
