How to handle log4j flagged in ArcGIS Portal and Pro directory?
305
10-23-2024 10:46 PM
Yogesh_Chavan
Hello,
Can someone confirm if the below flagged directories with log4j be considered unsafe? We are using ArcGIS Enterprise 11.3 and these components were flagged on the ArcGIS Portal machine.
Directory of C:\Program Files\ArcGIS\Portal\framework\runtime\ds\framework\lib
log4j-1.2-api.jar
Directory of C:\Program Files\ArcGIS\Portal\framework\runtime\ds\framework\runtime\opensearch\plugins\repository-gcs
log4j-1.2-api-2.20.0.jar
Directory of C:\Program Files\ArcGIS\Portal\framework\runtime\ds\framework\runtime\opensearch\plugins\repository-s3
Directory of C:\Program Files\ArcGIS\Portal\framework\runtime\tomcat\lib
log4j-1.2-api-2.22.1.jar
Directory of C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\saspy\java\iomclient
 log4j-1.2-api-2.19.0.jar
Directory of C:\Program Files\ArcGIS\Pro\java\runtime\spark\jars
ChrisUnderwood
Hello @Yogesh_Chavan , you don't mention what security scanner you used to generate this list. False positives can be a problem with many scanners. Check whether you are using one of the scanners listed in the Security Scanner False Positives section below.
https://www.esri.com/arcgis-blog/products/arcgis-enterprise/administration/arcgis-software-and-cve-2...
ChrisUnderwood
Yogesh_Chavan
Thank you for the details @ChrisUnderwood, I can check these details with the IT team.
