How to create a Server Admin so I can disable the PSA
787
03-07-2025 06:30 AM
JohnSteed1
I am working through Security Best Practices for ArcGIS Enterprise and am trying to disable the PSA for Server, but would like to create another general administrator since I use Server Admin almost every day.
I have not found any resources that describe how to create another Server Admin to help with this.  How do you create another admin in Server?
Note: My Server is Federated with a Portal.
A_Wyn_Jones
Since your ArcGIS Server is federated with Portal - you can create a Portal token to allow you access to your ArcGIS Server admin endpoint.
Visit: https://my.portal.com/portal/sharing/rest/generateToken
In web app URL, paste the URL of your ArcGIS Server admin endpoint. This might looks like this:
https://my.portal.com/server/admin
or
https://myenterpriseMachine.my.domain:6443/arcgis/admin
Then provide Portal credentials (admin). Once you've generated the token, copy it and bring it back to the ArcGIS Server admin endpoint and use it to sign in.
Portals sign-in has lockout (e.g. blocks your IP after X amount of attempts) which makes this the more secure method.
"We've boosted the Anti-Mass Spectrometer to 105 percent. Bit of a gamble, but we need the extra resolution."
