How to bind fetched items from ItemFileReadStore to a table td vertically not datagrid
2317
06-16-2016 09:59 PM
SadanandacharB1
Hi All,
         I am binding items to data grid table as shown below,
        function executeIdentifyTask(geom) {
            //clear the graphics layer
            map.graphics.clear();
           // var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new        esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DOT, new dojo.Color([151, 249, 0, .80]), 3), new dojo.Color([151, 249, 0, 0.45]));
            symbol = new esri.symbol.SimpleMarkerSymbol();
            symbol.setSize(10);
            symbol.setColor(new dojo.Color([255, 255, 0]));
            identifyParams.geometry = geom.mapPoint;
            identifyParams.mapExtent = map.extent;
            identifyTask.execute(identifyParams, function (response) {
                var parcelItems = [];
                dojo.forEach(response, function (result) {
                    var feature = result.feature;
                    //add selected feature to graphics layer
                    feature.setSymbol(symbol);
                    map.graphics.add(feature);
                    if (result.layerName === 'SPL_NSDI') {
                        parcelItems.push(feature.attributes);
                var parcelsStore = new dojo.data.ItemFileReadStore({ data: { identifier: 'ID', items: parcelItems } });
                gridParcels.setStore(parcelsStore);
  <table dojotype="dojox.grid.DataGrid" jsid="gridParcels" id="gridParcels" style="width:100%;height:100%;" selectionMode="none">
                 <thead >
                    <tr>
                      <th field="ID">ID</th>
                      <th  field="STATION_NAME">STATION_NAME </th>
                    </tr>
                 </thead>
     </table >
But how to bind the fetched items from ItemFileReadStore to table td not dojo data grid and table values should be vertical, Below is the code that how i fetched the items
  var queryObj = {};
                var value = null;
                var staionName = null;
                parcelsStore.fetch({
                    query:  queryObj,
                    onItem: function (item) {
                        value = (parcelsStore.getValue(item, 'ID'));
                        staionName = (parcelsStore.getValue(item, 'STATION_NAME'));
           //   return value;
Result should be like this
ID  1
STATION_NAME  Mysore
Please help on this issue..,.
Thanks!
MonaBrisco
Are you wanting to reverse the columns and rows?
