How to Automate Publishing Data to Map Image Layer?
2113
12-17-2020 01:19 PM
cardiokan
Hi all,
Can anyone recommend how to automate publishing to a map image layer?
I have recently been using FME server where you can publish data directly to feature layer. I was considering working out way to do this also for map image layer?
Can anyone recommend a solution. We also have access to a postgres database.
NoahKrach
The ArcGIS API for Python is a great tool for automating publishing process. The document below goes over some common workflows for automating publishing process. The section about publishing SD files might be of most use to you.
ArcGIS API for Python Publishing Workflows
NoahKrach
