How do you sort the contents of a pop up window?
426
02-03-2018 06:08 AM
by Anonymous User
Not applicable
I have sorted my data in ArcMap, and published a map service. In ArcMap, when I select a feature, the results are sorted as I want them to be. In the map service, when I select a feature, they are NOT sorted. The date field is what I want records sorted by.
When I open the attribute table, the results are sorted correctly. The popup window is just ignoring the sort.
In configure popup, can you set a sort field?
Thank you,
Randy McGregor
