how can i register my 'file gdb' or 'maps' on my arcgis server?
708
01-16-2014 03:04 AM
joong_ockyoo
Hello, I have a question.
How can i register my 'file gdb' or 'maps' on my arcgis server?
And if i register gdb or map file on my arcgis server, can guests edit them?
Also after quests edit them, modifed results can be reflected on my arcgis server?
I hope your help!
Noah-Sager
Hi Joong,
1) You can register maps to ArcGIS Server by publishing them as a service. Here is a link to documentation about how to publish a service.
2) There are a couple ways that you can register data, or a file gdb, with ArcGIS Server. Here is a link to documentation about registering your data with the server.
3) Editing depends on how you allow access to your services, and if you are working with a feature service, which will allow edits to be made and saved. Here is a link to documentation about working with services you've published.
Spend some time with the documentation and the tutorials that come with ArcMap, they are very useful. Hope this helps!
-Noah
