Having Issue on Setting ArcGIS Web Adapter
3026
08-24-2015 05:04 PM
BruceGreen
Using ArcGIS Server 10.2.2 on Windows Server 2012 R2 I am having problem on configuring ArcGIS Web Adapter. Here is what I have done:
1- I entered 'http://localhost:6080` in GIS Server URl box and used the same Administrator User Name and Password into the box (the ones which I used to create the server)enter image description here
but in result I am getting this error
2- In second try I used http://gisserver.mapapp:6080 which the mapapp is the name of machine running the server with same credential but now I am getting this error
Can you please let me know what I am doing wrong?
JayantaPoddar
Hello Behrouz,
Two things to check
1) Make sure the ArcGIS Server service is running.
2) If your machine's full name is "HOSTNAME", then the url should be
http://hostname:6080
If your machine's full name is "HOSTNAME.DOMAINNAME", then the url should be
http://hostname.domainname:6080
3) Also check that the following ports are allowed through firewall
Ports used by ArcGIS Server—Installation Guides (10.3 and 10.3.1) | ArcGIS for Server
Think Location
KumarHarish
Enable the SSL on ArcGIS Server?
Here is reference
http://resources.arcgis.com/en/help/install-guides/arcgis-server/10.2/index.html#//01nm00000033000000
On Tue, Aug 25, 2015 at 9:56 AM, Robert Scheitlin, GISP <geonet@esri.com>
JayantaPoddar
Hello Behrouz,
Two things to check
Think Location
