GP tool with Feature Set input not using template layer file
708
08-01-2022 02:54 PM
mattkramer
I have a geoprocessing tool published from ArcPro that takes some point geometry as an input. The input is in a GPFeatureRecordSetLayer parameter and utilizes a layer file to allow the user to input multiple types of points. This layer file is used in the tool when run in ArcPro, but when published to Portal, the input geometry only uses the default point geometry and no option for the users to select the point type and different symbology. Is there a way to get the hosted version of this tool to utilize this layer file and more complex input? Also is there a way to get the user to edit the attribute data of the input geometry? That would also be a workaround to this issue. Any help would be appreciated!
Using ArcGIS Pro 2.9.3 and on Enterprise 10.9.1
