GIS Server 10.2: Server object extension 'featureserver' not found.
5614
12-20-2013 06:26 AM
JoseSanchez
Hi all,
I am installing the Citizen sample  for 10.2 and testing it,
http://resources.arcgis.com/en/help/localgovernment/10.2/index.html#/What_is_Citizen_Service_Request...
When I run the application it shows an error message when it tries to access the feature
http://<myserver>:6080/arcgis/rest/services/Citizens/ServiceRequest/FeatureServer/0
Error message:
Error: Error handling service request : Server object extension 'featureserver' not found.
Code: 500
JustinRodriguez
Hi all,
Error message:
Code: 500
Hello,
I think this error would most likely be caused by you simply not having a proper SDE Database registered with your ArcGIS for Server. Would you double check your validations for the Database containing the data for the Feature Server please? Thank you-
Justin
JoseSanchez
How do I register my "SDE Database  with ArcGIS for Server" ?
Hello,
Justin
JustinRodriguez
Hello again,
Please check out the resources found here:
http://resources.arcgis.com/en/help/main/10.1/index.html#//015400000505000000
Thanks-
Justin
