Get new web apps for enterprise
1078
02-13-2020 05:21 PM
DavidCook2
What is the best way to get new releases of web applications on an on premises enterprise deployment?
For instance, AGO has a new attachment viewer web app, but it is not available as a default option with enterprise 10.7.
Unsure if:
Portal updates enable this
10.8 update would capture this
Do I download the app fro AGO and host it
    If so, does it remain a configurable template, or does each new version of the app need to be pre configured before hosting
Any links or resources would be greatly appreciated.
Thank you,
DerekLaw
Esri Esteemed Contributor
Hi David,
> AGO has a new attachment viewer web app, but it is not available as a default option with enterprise 10.7 ... 10.8 update would capture this
You're correct, this configurable app template was added to ArcGIS Enterprise 10.8.
What's new in the ArcGIS Enterprise 10.8 portal—Portal for ArcGIS (10.8) | Documentation for ArcGIS ...
(see Configurable app templates section)
> What is the best way to get new releases of web applications on an on premises enterprise deployment? ... Do I download the app fro AGO and host it
Downloading and added new app templates into Portal for ArcGIS is not a supported workflow. Sorry. Upgrading to the next ArcGIS Enterprise release is how you get new app releases.
Hope this helps,
