Geodata service not responding
1198
10-23-2019 08:16 PM
SOVANHALDER
 We have got strange issue while sync data using replica in geodata service. The sync process gives bad syntax in request  error. We have found while accessing the geodata service from rest end point it is giving timed out error. We are not able to to see the replicas.
Can anyone help?
TIA
S
BrunoBlanco
Hi Sovan,
I ran across this thread as I was troubleshooting some issues that I'm having with our geodata services (not exactly the same problem).
I'd recommend going to your server manager and checking the pooling timeout allowance. By default, geodata services come with the timeouts listed in the screenshot below, but maybe you need to increase them in your case? Just an idea.
It could also be that you need more instances to be available at any given time.
