GeoCoding service input parameters
1362
09-17-2014 09:43 AM
MarkCollins
Hello,
I am trying to figure out how to modify/customize the input parameters on a GeocodeServer service.
I have built a locator and published a geocoding service (ArcGIS server 10.21) that has input parameters of: street, city, state, zip. I need to change the name of the street parameter to address. What is the best way to do this?
(My client application using the service is expecting to be able to send an input parameter of Address.
Mark
TimothyHales
Esri Notable Contributor
I've moved your post into the ArcGIS for Server space. You will get a much better answer here as the GeoNet Help is intended for community help and feedback. You can see more on the community structure, and what topics are under each space from the following documents:
GeoNet Community Structure
ArcGIS Discussion Forums Migration Strategy
Thanks!
Timothy
