FGDB in Azure Enterprise Deployment
221
08-10-2025 08:40 PM
MuhammadNaufalIhsan
Hello guys,
I have a client who publish services from file geodatabase in a registered sharing folder. Currently, they want to migrate the enterprise deployment to Microsoft Azure (and for some reasons they still want to keep their data in the file geodatabase).
Any recommendation what azure product we need to use as the replacement for the sharing folder? Should we use a VM as the sharing folder or can we use Azure NetApp Files?
Regards,
Naufal
SimonSchütte_ct
MVP Regular Contributor
Did you talk with the client and checked if using a hosted feature service with "update from FGDB" and "export as FGDB" from the Portal Item could be an option?
Here are related posts that may be helpful:
ArcGIS Enterprise and Azure Net App Files, Microso... - Esri Community
Azure Files premium file share - SLOW File Geodata... - Esri Community
PatriceLabbé
We're currently moving from Azure Files to Azure NetApp Files for performance considerations. Hope this helps!
