feature service table in arcmap
2318
09-24-2015 07:20 AM
JoshWhite
Honored Contributor
There are several discussions about adding a feature service and editing it in ArcMap but my issue is a bit different.  I access a feature service from the county I am in to obtain the parcel information.  The service is secure.  It was set up this way so that the information could be downloaded.  The feature service contains several sde layers and a table.  The layers show up just fine and I can export them, albeit a painful process, but I cannot see the table so that I can do a join, which is the whole purpose of the table.  Checking the service directory I see the ownership table and opening it in ArcGIS.com shows the table and I can open the attribute table and everything.  The only thing I can't seem to do is open it in ArcMap.  Is there some setting I am missing or is this a bug.  I am using ArcMap 10.3 and ArcGIS for Server 10.3
Josh White, AICP
Principal Planner
City of Arkansas City
