FAILED TO START THE SERVER
7542
7
05-08-2015 10:34 AM
panugantiviplaw_kumar
Hi
The followoing error message is giving after publishing the services to the server. am attaching the error below. kindly anyone provide the solution for it.
Service failed to start test_service.MapServer:
VIPLOVE.GISPORTAL.COM
JayantaPoddar
Hi Viplaw,
What capabilities have you enabled in the service while publishing? And what warnings did you see while analyzing the services in Service Editor?
Think Location
Hi jayantha
I have enable feature access in the service editor while publishing the services ...but today morning it started properly without giving any error message ..
Later sometime that published service is not starting
Regards
VIPLAW KUMAR
JayantaPoddar
Hi Viplaw,
What database are you working on?
Have you registered the database with ArcGIS for Server?
Think Location
Hi jayantha
I registered the DB n am using Postgres ..!this error is occurring when I restart the services .
VIPLAW KUMAR
JayantaPoddar
Try the following steps:
In ArcCatalog,
1. Right-click on the postgres database connection
2. Choose Administration > Permissions
3. Pick the Server\arcgis account and give it 'Read Only' permissions.4. Try restarting the service.
Think Location
Hi jayantha
I have tried that activity also even though it's showing that "services stopping" as service status .
Regards
VIPLAW KUMAR
DavidRunneals2
Re-validate your datastores and try restarting
gisserver.gis/manager/site.html > Data Stores > Validate All
