Hello!
While running ArcGIS Enterprise 10.8 Cloud Builder for AWS, I am receiving the error message "Failed to retrieve ESRI AWS CloudFormation templates for version 10.8". Is this expected? Is there any way to work around that? I was using the Cloud Builder to create test/mirror deployment, in order to upgrade successfully the production deployment.
Ualas
Solved! Go to Solution.
Issue fixed by Esri Case #02817913. Thanks for the effort guys!
I have noticed that Cloudbuilder.exe.config has set https://esriresources.s3.amazonaws.com/cftemplatesconfig.dat for CFTemplatesFileURL. This data file has a broken link for version 108 "Domain". I've tried to replace the broken link with https://arcgisstore108.s3.amazonaws.com/12790 but even after that I am still getting the error message.
How should I proceed?
@JonEmch @ReeseFacendini I'm wondering if you have any clue about this issue? Thank you!
Seems like there was an issue with one of the backend URL's in the cloud formation template. As you said above, I have confirmed that this issue was resolved. Thank you for working with support on this one!
