Failed to Register as Versioned
4524
07-17-2012 05:06 AM
TimEagan
In Arcatalog, as the schema owner I selected 'Register As versioned' with the option to move edits to base.  I get the 'Failed to register as versioned, table already exists' error.
I executed the sdetable register tool for a specific layer and it returns that the layer is already registered.
In oracle the Adds and Delete tables do not exist for this feature class.
I attempted to unregister the layer but received an error stating other objects had dependencies on the object.
Backgroud:
The data came from our old database which was on another server.  This data was versioned.  Each layer was exported to a file gdb first, then loaded into the new db.
Oracle 11.2.0.2
ArcSde 10sp3
Tim
CraigSwadner
have you tried deleting the table and reimport, then register as version ?  backup data first though.
