Failed to download package from server
1244
06-04-2021 10:04 AM
Sunnywaygis
Hi There, I am getting this 404 error/Failed to download package from server. I am not sure what maybe causing this. Feature service has sync capability enabled and data is sourced from feature class in SQL Server based enterprise geodatabase. Layers have globaID and archive enabled.
Appreciate any feedback.
Result Parameter: packages (SetupMapArea)
"paramName": "packages",
"dataType": "GPString",
"value": [{
"source": "https://testmap.com/rest/services/Explorer_DEV/FeatureServer",
"error": "{\"code\": 36, \"messageCode\": \"OffPkg_ 36\", \"message\": \"Failed to download package from server https://testmap.com/rest/directories/arcgisoutput/Explorer_DEV_MapServer/_ags_dataEF84D5AC7D024A7DA802114DCA5D9E8F.geodatabase?token=KPT_4BhVxYcQSX19jtmP70tn-iqwh03UdKENr6IO4WTT7HKjMYcqz_RGyxE9xd2C71QBc54lE9W8fMfFr0Y7yjvdmcO7rc8lBv27yTEStvdEJQaDl5TQM7rIHD_wz17b04Q32rdPuhPwJwDpsfLWvatn89edWjaCzc6T2JMvFVIoP2L5zKbfJnmwGLT4Dt9V , error HTTP Error 404: Not Found\", \"params\": {\"url\": \"https://testmap.com/rest/directories/arcgisoutput/Explorer_DEV_MapServer/_ags_dataEF84D5AC7D024A7DA802114DCA5D9E8F.geodatabase?token=KPT_4BhVxYcQSX19jtmP70tn-iqwh03UdKENr6IO4WTT7HKjMYcqz_RGyxE9xd2C71QBc54lE9W8fMfFr0Y7yjvdmcO7rc8lBv27yTEStvdEJQaDl5TQM7rIHD_wz17b04Q32rdPuhPwJwDpsfLWvatn89edWjaCzc6T2JMvFVIoP2L5zKbfJnmwGLT4Dt9V\", \"error\": \"HTTP Error 404: Not Found\"}}"
jcarlson
MVP Alum
What are you running / selecting to initiate this process?
- Josh Carlson
Kendall County GIS
